GGB Bearings Go to Mars
Bearings manufactured by GGB Bearing Technology, an EnPro Industries, Inc. (NYSE:NPO) company, are helping NASA’s Curiosity rover explore the surface of Mars. GGB’s DU® metal- polymer bearings are critical components in the drill that Curiosity is using to sample rocks in the Martian landscape.
GGB bearing _Mars
“It is a great honor for GGB bearings to be used on the Curiosity rover,” said Ken Walker, GGB division president. “Our products are used in tens of thousands of critical applications every day on our planet, but it is always our goal to provide superior, high-quality solutions to our customers’ needs, no matter where those needs take our products.”
The self-lubricating DU® bearings feature high resistance to wear and the ability to function in the harsh conditions and temperatures found in the Martian atmosphere. The bearings can operate successfully at temperatures in a range from -328 oF (-200oC) to +536 oF (+280oC).
Engineered and built by NASA’s Jet Propulsion Laboratory in Pasadena, Calif., Curiosity’s mission is to investigate conditions on the planet to see if they may have been conducive to microbial life. The investigation requires obtaining and analyzing dozens of samples scooped from the ground or drilled from rocks. A robotic arm on Curiosity is capable of drilling into Martian rocks to a depth of one inch, or 2.5 cm. The drill acquires samples by rotating and hammering the rocks with weight applied to the bit.
Three DU® metal-polymer bearing segments serve as the primary suspension components for the drill spindle, one of four robust components that allow the drill to operate in the environment on Mars. In addition to the spindle, which rotates the bit, the drill includes a chuck that engages and releases the bit; a percussion mechanism that hammers the bit: and a linear translation mechanism.
In addition to their use on Curiosity, GGB’s DU bearings are used in a diverse range of industrial applications on Earth, and are well-known for offering excellent low-friction performance and wear resistance in a wide range of loads, speeds and temperatures.
Source: GGB Bearing Technology
CGB Precision Products will distribute OAV Air Bearing products in the Australian and New Zealand marketplace
CGB Precision Products will distribute OAV Air Bearing products in the Australian and New Zealand marketplace(0)
The  US Air Bearing manufacture OAV Air Bearings announced it has established an agreement with CGB Precision Products Pty Ltd. to distribute their air bearing products to the Australian and New Zealand industry! CBG Precision Bearing Products Pty Ltd offer a variety of specialist bearing products and support services to a wide variety of industry
ZKL launched Cylindrical Roller bearing PLC_412-63
ZKL launched Cylindrical Roller bearing PLC_412-63(0)
Employees of ZKL successfully finished development and production of a large dimensional cylindrical roller bearing PLC_412-63 for important foreign customer. For a better imagine, here are the basic parameters: Outer diameter: 900 mm Height: 210 mm Weight: 612 kg Finishing operations turning and grinding of components were made on modern machines, which were obtained with
