RKB extends its range of split spherical roller bearings
The RKB heavy duty split spherical roller bearings (SSRB) are designed to meet the special challenges of the aggregate industry. These bearings employ a convenient arrangement for easy on-site assembly into applications that often have only seasonal maintenance. Not only is access limited to related shafts/housings, but shutting down to change bearings is usually not an option, making bearing life a prime consideration. The SSRB 321606AA is one of the compact series produced by RKB with main boundary dimensions of 140x230x53/102 mm.
RKB split roller bearing
source: RKB
Single Turn Wave Springs
Single Turn Wave Springs(0)
